First pc (build)
like the title says this is gone be my first pc build and even my first pc have a laptop though :)
i was thinking about this build
and i worked around 250 hours for the money so i am realy enthousiast for building it, its also gone be my first build so if you guys have tips please tell them.
  • Budget. How much are you willing to spend? €750
  • Where do you live (what country),  and what currency do you use? euro's
  •   -Is there a retailer you prefer? the cheapest one
  • Do you need or already have peripherals? (this can add to costs) i have an old screen and keyboard and mouse i will replace them when i have the money
  • What will you be using your future computer for? Gaming? Rendering? Mix of both? Or is this a home media PC? primarly for gaming i know i dont have a gpu but wil also buy it later when i have the money. and also a bit of rendering
  • Do you overclock or want to get into overclocking? yes i want to get into overclocking i wil also buy another cpu fan and again when the money is there
  • Do you plan on going for custom watercooling now, or in the future? no custom watercooling for me
  • OS. Do you need a new one? no i have a copy of windows 8 laying around
If you Game-
  • What kind of settings do you like or what FPS do you want to play at? 40+
  • What resolution will you be playing at? //or would like to play at. probaly 1080p
  • What kind of games do you like to play? shooters indie en free to play
  • What specific game will you be playing (if you only really play one)battlefield 4 and titanfall do i want to play dont play them now because dont have a pc/laptop that is powerfull enough
If you Render or Edit things-
  • What application do you use to render? (very important) cinema 4d not realy some real powerfull things but maby later
i also later gone buy a new screen when i have the money so do you have any advice for screens
do you have any questions about the parts or other just ask :)
so i just want know if this is a compitable build and suggestions for gpu's screens that i want to buy later
also sorry for the bad english it isnt my first language and only 15
 thanks already
There are different country links in PcPartPicker.  In the top right hand side of the page, select the country that you'll be buying from and the currency and part availability will pop up.
The i5-4670k is a strong CPU, but without a dedicated graphics card it won't be able to run many games smoothly.  At this budget, an AMD build with a weaker CPU but with a decent dedicated graphics card will perform much, much better at a lower price.
Since prices are often more expensive in places other than the US, I went easy on the budget.
I went with a smaller case, as a full size case isn't needed.  Full size cases are BIG.
A smaller power supply will work just fine, unless you want to add another graphics card in the future.
http://pcpartpicker.com/p/3kOlO
The 8 cores will help a lot in future games and rendering.  Single core performance is not that far behind Intel's i5.  I added a budget CPU cooler that performs relatively well, so you can overclock it as well.
I had to lower the SSD capacity to 128GB.  If you want more capacity, you could probably remove the 1TB drive and up the SSD capacity.
Cheaper memory that's the same clockspeed.
the country i live in isnt available there on pcpartpicker
I know i wont be able to run slot of games with only the gpu in the i5-4670k, but its almost holiday so i can work and ad an better gpu like the r9 270x, and i just loved the phantom case and have the room for it. And about room i want to get the 250 GB and have an old 500 gig drive laying around. But i maby go with that ram
But the system i had was compitable right?
Thanks in advance
I would then rather get the fx 8320 with a decent motherboard and then bump the GPU up to a 280x or a GTX 770.
In the end the cost should end up the same, but you will gain more performance due to a better graphics card.
With memory, you generally wanna find the cheapest 1600/1866MHz with a CAS latency on 9/10.
I'll edit this post with a build soon enough
EDIT;
http://pcpartpicker.com/p/3leoG
i searced on your build but its way more expensive then the intel version i choose because some parts aren't avaible in my country. and the corsair ram was actualy the cheapest i could find.
 but yeah if i would put a graphics card in the intel build it would cost the same but i dont have that much money on the moment, so would it be a better idea to pick the intel build and ad a gpu later so i can buy the build next week and finaly have a better pc then  my cheap laptop?
That can work.  I have personally done the same thing with my rig; I purchased everything except my GPU.  I play source engine games, which are easy to run on my i5-3570k.  A month later, I picked up an HD 7950.
okay thanks i think i am going to go with that
thanks for al the answers
