First pc Build :)
i am wondering if the selection that i chose will be suitable for a $1500 gaming and editing pc.  If have any suggestios to make this build even better than PLEASE COMMENT THEM BELOW!!!!!
http://www.pcpartpicker.com/p/NmQh
Why are you spending so much on a DVD drive?
Why no SSD?
If you're not going to use CUDA, get a 7970.
Your PSU is way way way overkill.
pick a smaller size of thermal paste you will never use 40gs of it anless your Building a 100 pcs :)
but it looks good alltho ied drop the water cooler and buy a ssd if it was my rig and fit a good air cooling unit
