First PC Build
Hi all, this is my first build and so I'd like to hear your opinions on it.
http://uk.pcpartpicker.com/p/BCLd
Money isn't too much of an issue so I don't mind how expensive it is, I'm more worried about compatability etc.
Charlie
 EDIT: Here is an updated version, wondering if its still compatible (I assume so, only changed motherboard which has the same specs pretty much, bigger SSD and HDD)
http://uk.pcpartpicker.com/p/BSV7
You're good to go, only thing I moght say is that a 2TB Seagate isn't that much more expencive, so might chose that one instead. But everything is compatible and no bottlenecking
Are you sure money isn't an issue? Because if it wasn't, I would expect some better quality parts.
Thanks Traxer :) Ill have a look at the 2TB now.
Vortex, I meant that I wasn't looking for input on cheaper parts so no need to suggest any, I have a bit of a budget in terms of I don't want to spend more than about £1,200-£1,300.
EDIT: I've changed the SSD to this
and the HDD to this
What are peoples opinions on the motherboard? I'm not an expert on them.
For the motherboard, its the Same price and is a excellent board. Maybe try this one: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293 Its really good for overclocking (very simple too.) Its actually the one I'm using myself with the same processor and its awesome.
Nice idea Nitro, I've changed the motherboard to this and updated the build in the first post
