First Pc Build
Thanks for your time and checking this out. i'm very new to this and i want to build a gaming pc. will this set up work? I have a budget cant go over 660.
CPU: Amd phenom II x4 965 black edition
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
Motherboard: Asrock 970 extreme 3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157280
Memory: Patriot intel extreme master (2 x 4gb)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220705
Storage: Western Digital 500gb
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
Video Card: xfx radeon hd 6870 1gb
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150561
Case: Sentey optimus extreme division case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811322016
Power Supply: Corsair cx500 500 w
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
Drive: Asus 24x dvd burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Total After $626
will this work out?
thanks again.
looks really good but I would recommend a little more hdd space and a 7850 check my links below
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102998
I currently have a hd 6870 I bought over a year ago for a build, if i was you i'd try for somthing from the 7000 series. Everything else looks good. If you can get a cheaper mobo or disc drive you could put more money towards the cpu or gpu.
thanks for your help.
im going to get that harddrive.
i'l look into what you said thanks for your time and help.
This goes below $660 after rebates, and a measly $10 more before rebates( well worth the $10)
Don't forget about the OS.
i will be useing windows 7
