I am planning on building my first pc.I put together this list on pcpartpicker.com and i was hoping to get some suggestions and help to see if this would work. i was also wondering about the bios update for the motherboard
www.pcpartpicker.com/p/2xsnS
thanks
id really recommend getting a 990 board. if you plan on upgrading it later to a 8350 or better possibly, you will not have to buy another mobo. its better to just start with more than what you need, so that you can upgrade in the future. 990 mobo are better at overclocking, performance and balance than 970s is i recall correctly. theres also that BIOS incompability *
EDIT: forgot to mention, go with a 6300 if you plan on overclocking. if not the 6350 is good
I have that same mobo with the FX 6300. While it works okay, I couldn't recommend it due to the fact that if you ever upgrade to an FX 8350, it will most likely throttle it due to the board only being able to handle 125w max TDP. I also would not overclock with that board because a)It has a 4+1 power phase and b)It has terrible VRMs that will blow if you push the board too high. That is an FX 6350 which has a 125w TDP. It will probably work with the board but it may possibly throttle it. I have read on some forums that people have successfully used FX 8xxx CPUs with that mobo, but their CPU is most likely being throttled and I certainly wouldn't recommend it. I've read that you could eventually hit a spike in CPU usage and that could blow your board. If you stay with an FX 6xxx CPU, and don't overclock, then you will be fine.
That particular board is compatible, well as long as the bios is updated, which the update was released at the beginning of the year(not sure when) so unless the OP gets shipped an old board which they didn't bother to update the bios, they will be fine.
G46 can handle barely handle the 8350. Getting a mobo like the Asus M5A99FX Pro R2.0(990fx board) will be much, much better.
I was also considering on waiting for new stuff to come out. should i wait or just go for this build with a better motherboard
Well, the Kaveri APU's are coming out in a few days, and that may be worth checking out. Not sure how they stack up to the FX CPU's though.
This might be a little bit better: http://pcpartpicker.com/p/2A5gS
