Hi, This is my first ever PC build. I will be using the AMD FX-8350 as the CPU. My budget is about 680$ not including the old parts.
http://pcpartpicker.com/p/C3kT
NOTE: I going to be reusing my storage, disc drive, and my old AMD 7770 from my last computer.
Please give me feedback on this build.
yeah seems legit....(I am being serious)
its funny because the above is about 60% of your pc (because your reusing) and its already the same as my whole budget -.-
bald
3
You will nmot need 16 gigs of RAM, get 8.
The corsair H50 doesnt really cool well for the price, get an aircooler like the corsair V8 or that one noctua i cant remember the name of.
The PSU is also a tad big large but that doesnt really cause any trouble.
But think, you'll never have to go and buy a whole computer again. You can always just change as you go.
To OP; I suggest a different cooler, like a Noctua or NZXT.
I changed the H50 to a H100.
Also, will my current build work as it is?
