First pc build used for gaming! Please let me know what you think!
http://pcpartpicker.com/user/Dmoney69/saved/1jER
Need a aftermarket cooler like a hyper 212 evo
You may need a bios update to use that chip on that mobo only the first Bulldozer chips are supported out of the box
Budget?
Would this mobo be bette. http://pcpartpicker.com/p/O15D
800$
The only improvements I could seem to make was on the RAM and Hard drive and motherboard but it costs a little more. I would also advise you get an aftermarket cooler too if it can still fit in your budget.
http://pcpartpicker.com/p/O18o
EDIT:
http://pcpartpicker.com/p/O1az
This build is little over 800$, but for the price your are getting so much
http://pcpartpicker.com/p/O4y0
http://goo.gl/DPhNn
http://pcpartpicker.com/p/O8GZ
Dude your PC Part Picker build doen't have brain(CPU)!
Really?
Very perceptive of you, did you bother to check the first link?
