First PC Build Troubleshooting
I just finished building my first PC the other day after making the switch from consoles and am running in to some trouble. After loading up Windows 8.1 and proceeding to update Windows and install updated drivers I am running into some issues. The updates will download and install to the PC, yet when it tells me to restart the computer the issues start. Upon restart it acts like it will start up windows yet the only thing that will appear is a colored screen ( the one chosen during setup). I have tried waiting for the screen to change to no avail no mater how long I wait. I have also restarted the machine multiple times. The only way I have been able to get around it is to reinstall Windows. Any and all help is appreciated.
Build list:
i5-3570K
EVGA 760
ASRock Z75 Pro 3
CoolerMaster Hyper 212 Evo
GSkill 8gb RAM
Corsair CX500M
Samsung 120gb SSD
WD 1TB Caviar Black
Seagate 1TB
Let me know if you need any more specs.
Interesting. I would do a fresh install of Win8 myself after backing up the files I wanted/needed. I would however do the fresh install with only the hard drive or SSD you are using for your operating system with plugged in. Unplug all other hard drives. Then plug in the other hard drives. I have a blog post relating to this (installing windows with multiple hard drives connected). It caused me some issues.
All that being said, a fresh install may not be necessary although that would be my personal choice if you don't have a lot of stuff installed already or you backup your system regularly.
I will try that tonight and see if that helps.
Sounds good, remember only one hard drive plugged in ;)
If that helps you solve your problem, let me know.
Well I tried your suggestion and at first it did not work and the same problem occurred as above. So I shut down the machine and came back to it later, and amazingly it booted up and worked! I am so glad it worked out though it is weird in the way it happened. Thanks for the help.
