Hello everyone!
I just got the parts of my 1st pc, and i wanted to know what you guys think of it. Decent?
http://ca.pcpartpicker.com/p/3IUMW
Thank you in advance for all the feedback, have a great day.
Hello everyone!
It looks like a good list. Unless you really need HyperThreading, Id go with an i5 4670k, and step up the GPU if ya can. Also as someone with a NZXT 410, It has pretty bad airflow, so you'll want a bigger cooler than the stock one, and some 120mm case fans especially with an AMD GPU.
But the current list you have is great.
I already bought all the parts, do you think i can still build it with no problem? Or the extra airflow from the fans or cooler is a must?
I think you will be find for a little bit, but within a month maybe 2, they are a must. Even something like a Cooler Master hyper 212, and some cheap fans will do you great things
Awesome, thanks! Also, do you think getting an Anti-Static wrist strap is a must? I want to build it right now but i don't have the strap.
ive never used one... just discharge (touching something grounded).. and dont build it on a rug lol.
just ground yourself on any metal part of the case. and avoid working in carpets metal tables, work in wood tables to avoid static buildup. Also i would get a bigger PSU, since the 270X drinks a lot of power. CX700 or better should be good, it's always nice to have an overkill power supply.
Very nice man. Gratz.
