First PC build! thanks Tek Syndicate!
I randomly started youtube'ing computer videos about 3+ years ago (whenever the i5-2500k and GTX 560 Ti were out lol) and since then i have wanted to build my own.
took many years of putting build specs together, only not to have the money. finally got a chance to, and it has been a dream come true.
Only problem i had was that i couldn't get the damn Maximus VII Hero I/O back plate in the NZXT H440 right. so just left it out.
On the plus side, i bought am EVGA G2 750W 80+GOLD fully modular PSU for $105.... box came.. box says 750 G2.... but i got an 850 G2 in it XD gotta love it. Here is the build!
http://imgur.com/gallery/8fF7a
On a side note. i bought my own RJ-45 crimper (came with a cutter, tester, and 100 RJ-45 connectors) and terminated my first CAT cable (CAT-6a). was using the T568B wiring. (currently table a voice and data cabling class lol). worked perfectly.
Special Thanks to Logan and the whole Tek crew, and also Linus and Carey Holzman. been watching them since back when i got interested in it.
Getting a GPU in April.. but next up... Overclocking lol. aiming for 4.5GHz.. but idk, we will see.
got Windows 8.1. Any suggestions about making Windows or my SSD more efficient?
lol good job with that 850w G2.
Looks great so far.  As for your SSD, there's not a whole lot.  You can have a load of programs that launch on startup and the SSD will run them all with little to no hiccups.
yeah, i just remember a Tek Syndicate vid about SSD setup (i think Max did it). and i just figured some of that stuff was due to the sizes of SSDs back then and the older tech. I have TRIM enabled, about all i have done. and i turned the power setting of the CPU to high performance or whatever. was on balanced, which had my CPU idle at 800MHz, which is fine, but i am on integrated graphics, rather just have it on lol
Looks pretty good.  Now you just need some storage and a GPU.
Yup. will have to wait till April though. most likely a GTX 970, and a WD blue 1TB. might cannibalize my cousins onld PC and use his old HDD
