Hey folks! So, I've finally decided to make the jump from console to pc gaming and was hoping to get some advice on what GPU would work best with my system.
I purchased the following build from cyberpowerpc (actually got a decent deal). Came out to be around $200 dollars cheaper than buying the parts separately.
http://pcpartpicker.com/user/SlyR/saved/2WaH
I would definitely like to play at 1080p as well as have high framerates while keeping prices to a minimum. I play games of all genres (FPS, RPG's, MMO's), The monitor I'll be using will be the:
http://www.asus.com/Monitors_Projectors/VG248QE/
And side question, which OS do you recommend?
Thanks all!
If money is no object, go with a 7950
If you want the best match, go with the 7870
flipping good GPU, if ya ask
Is there a vast difference in performance between the two? And are there any particular 7870's or 7950's that you recommend?
Thanks!
Well could be just me but i would build this: http://pcpartpicker.com/p/29nEF for $900.
and add an SSD later on ☺
This was really helpful. Thank you, I appreciate it!
"if running high screen resolution the 7870 is the winner"
I have no idea who makes that statement but 1280 stream processors vs 1792.. 2GB vram vs 3GB vram... i think youve got your ansewr..
Offcourse a 7950 is a winner in every category especialy wenn gaming on higher res 1440P.
Yeah, that threw me off when I read that. Going with all the reviews and the from the the input here, I'm rolling with the 7950.
