I've been generally working with Windows-based PCs my entire life, but I never once thought about building my own. Quiet honestly, watching the "Kill your console" videos really turned my head around. Unfortunately, there's too many parts to choose from and I'm having a bit of a hard time.
Generally what I'm looking for in a build is something that can be used for graphic design applications (Adobe CS6), gaming (Highest settings possible), and 3D modeling (Zbrush, Poser Pro, Luxrender etc). I'm hoping that someone here can point me in the right direction for a budget of around $2500 USD. Many thanks to anyone who can help me.
I did see that video, but it's well above my budget. I do not have a copy of windows and from the research I've done on cases, I'm leaning more towards the Fractal Design XL in Black/Pearl. As for peripherals, I've got that covered and already paid for. This is strictly for the computer build.
If you really want to max out every game I suggest you get a GTX 780, its a $650 card but when overclocked it can match the performance of the worlds fastest card the Nvidia Titan which is $1000.
?? why exactly ?? Their failure rate is low, good warranty, excellent seek times. Go to any pc store and check out the RMA bin, its not full of hitachi's - its budget seagates. If you had one that died then bad luck, but these are good drives. No manufacturer is immune to the odd item that fails thats what warrantys are for.
