First PC build * Need some help soon getting the parts soon
In Teks video Build a PC for 650$
he showed the ((ADATA XPG V1.0 series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model AX3U1600GC4G9-2G))
 But they are out of stock for them and i found the ((ADATA XPG V1.0 8GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model AX3U1600W8G9-RB)) OR ((HyperX 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C9D3K2/8GX)) and im going to use the
((GIGABYTE GA-78LMT-USB3 AM3+ AMD 760G + SB710 HDMI USB 3.0 Micro ATX AMD)) Motherboard
 , so i was wondering if the ((ADATA XPG V1.0 series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model AX3U1600GC4G9-2G)) OR ((HyperX 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C9D3K2/8GX))
and the GIGABYTE Motherboard are going to be compatible and work properly.And I was wondering if i could have 2 or 3 of the same ram on the Gigabyte motherboard because I want to have at least 16 or 24 gigabytes of ram on my computer.
Thank you
skystream
are you looking for a m-atx build? or does size not matter? because those m-atx am3+ boards are not realy the best quality.
+1
If you want anything smaller, I suggest Intel or FM2+.  If you want AM3+, get a good ATX board.
Do you guys know any builds new in 2014 that are good for gaming and around 600-800?
I watched the 650$ build for december 2013 i was going to get those parts but i dont know if they are going to be good. If anyone would like to help me, i would like to know a good build for 2014 that aroud 600-800.. please thank you.
http://pcpartpicker.com/p/3dPk9
This is about 680 and is a pretty good setup for your price range
