Hello everyone! I'm a long time console gamer and now going to build a budget gaming/general web surfing pc. I will be playing older games (2013 and older) on this pc, since I have a ps4. For budget reason I think the AMD apu is the way to go. I have already purchased several parts and just looking for some advice on the build and maybe something I overlooked that would be better...
I have purchased a few parts to get the build started:
Rosewill FBM-01 case
Corsair cx430 ps
LG dvd reader/writer
Seagate Barracuda 1tb hdd
Now for the parts that I am considering:
MSI a88xm gaming micro atx mb
AMD a10 5800k apu
Aftermarket heatsink of some kind????
And maybe somebody can point me in the right direction for ram? I will probably have to get some low profile ram since my case is small and the aftermarket heatsink will most likely be bigger...
So yea, any advice or feedback would be great! Look forward to being an active member on the forum and pc gamer!
well I would recommend GIGABYTE GA-F2A88XM-D3H it is $40 cheaper then the MSI a88xm and you can use that extra money to get a a10 6800k and if you could spend $30 dollars more by not geting a heatsink which is not super necessary i would get a a10 7850k and you could always get the heat sink later if you really want it. for the ram, i would recommend high speed ram because the ram speed makes a difference with APUs so I would recommend G.SKILL Ripjaws X 2133mhz ram. here is the link to all the product i recommended.
A10-6800K: http://www.amazon.com/AMD-A10-Series-Desktops-A10-6800K-AD680KWOHLBOX/dp/B00CPLGGXM/ref=sr_1_3?ie=UTF8&qid=undefined&sr=8-3
A10-7850K: http://www.amazon.com/AMD-A10-Series-APU-A10-7850K-AD785KXBJABOX/dp/B00H7Z7YMI/ref=sr_1_2?ie=UTF8&qid=1408160411&sr=8-2
GIGABYTE GA-F2A88XM-D3H: http://www.amazon.com/GIGABYTE-GA-F2A88XM-D3H-Bolton-Micro-Motherboard/dp/B00FU829ZQ/ref=sr_1_1?s=electronics&ie=UTF8&qid=1408160736&sr=1-1
G.SKILL Ripjaws X 2133mhz: http://www.amazon.com/G-SKILL-Ripjaws-240-Pin-Desktop-F3-17000CL11D-8GBXL/dp/B0050119O0/ref=sr_1_2?ie=UTF8&qid=1408160082&sr=8-2
Thanks for the advice! How does the 6800k and 7850k perform as far as overall computer applications? Like I previously mentioned I'll be doing quite a bit of web surfing and media downloading. I want a good overall computer that I can play older less demanding games on.
Also is the ripjaw ddr3 shorter than the corsair vengence ram? Because I know the the heat displacement on the vengence sets too high for my case...
budget is around $250 for motherboard, apu, and ram. I already have case, ps, hdd, and optical drive...
What do you guys think of this setup?
http://pcpartpicker.com/parts/partlist/
