First PC Build - Looking for tips and some guidance
Hello. I have started planning on my desktop build. I’ll probably build it in September.
I am working as a 3D artist, I’m using wide range of software, such as Adobe Suite, Cinema 4D, ZBrush. I also render a lot of physical accurate renders with Octane Render. Besides that, I’m also a gamer. I mostly play mmo’s, but I like pretty much everything.
I had little to no knowledge a week ago, regarding building custom PC, and since then I’ve been doing some research and decided a few things:
First, I need a x299 system, because Intel is a better choice for the software I am using and I need those extra PCIE lanes.
Also, I will start with one GTX 1080 Ti but I need to have an option for an upgrade to two or even three GTX’s in the future.
For RAM, I want to start with 2x16 modules and later upgrade it to 4x16.
I have no experience or knowledge about overclocking but I might decide to learn and play with it in the future. I know 7900X heats alot and I would probably need a custom loop water cooling for that, which I also have no experience with, but I would be willing to give it a shot in the future.
Budget: £ 4000-5000 (including keyboard, mouse, monitor)
At the moment I have these parts in mind:
Case: H500P Coolermaster
Motherboard: Asrock X299 Taichi
CPU: i9-7900X
CPU cooler: NH-D15 or Dark Rock Pro 4
GPU: GTX 1080 Ti (Not sure which brand)
RAM: 2x16 GB
SSD: 512GB/1TB
HDD: 3TB+
Monitor: probably 1440p 144hz
Things that I would need help with:
Which RAM should I choose. Should I go with 3200Mhz, even though I couldn’t use it without oc? Also, how can I make sure that it will fit with the cooler and the case? I know NH-D15 can be shifted upward, for a little extra space, but then I am not sure if the case is large enough.
I watched the video of Level1Tech review on ASRock x299 Taichi, he mentioned some things about connecting m.2 ssd’s to the motherboard and bottlenecks. I am a little confused by all that information and I am not sure which SSD’s I should be looking at.
If anyone could spend some time to help me with this and see if I haven’t made any errors that I’m not seeing I would really appreciate it.
Thank you.
Not sure I can help you. Adobe uses CPU horsepower more than GPU. So with abode go for all the CPU power / cost. So intel is out the window then. If your time line is september then threadripper 2 should be landing about then.
On the other productively suites I dont know. What you listed will get work done regardless.
Hey. I’m aware of Adobe using CPU. To be honest, I need to focus on pretty much everything, single-core cpu speed, multi-thread cpu speed, and gpu speed. I’m pretty sure 7900x and 1080 ti ar the best choices for me. I’ll do some research regarding threadripper as well, I’m not sure if it’s properly supported for Cinema 4D and Octane.
What I’m mostly concerned about is that I get the parts that go well together and that I don’t buy something that I won’t be able to properly use with my build.
P.S. Could someone tell me what power supply this build would require?
650W would be just fine.
My personal favorite is Seasonic Focus + gold… It’s not crazy expensive like a lot of them and have 10 years warranty. And it’s Seasonic…
What I would suggest is you getting the H500P mesh, because it cools better and it’s better built overall…
I was soo ready to recommend Threadripper when you said you use the Adobe Suite, Cinema 4D, etc then you said you only want an Intel system. Sorry but I haven’t been paying attention to intel stuff lately.
EDIT** Just in case you change your mind about your build. Only $3700 vs your £4000-5000 budget
PCPartPicker part list / Price breakdown by merchant
Type Item Price
CPU AMD - Threadripper 1950X 3.4GHz 16-Core Processor $878.99 @ Amazon
CPU Cooler Corsair - H100i v2 70.7 CFM Liquid CPU Cooler $107.89 @ OutletPC
Motherboard ASRock - X399 Taichi ATX TR4 Motherboard $323.98 @ Newegg
Memory Corsair - Vengeance LPX 32GB (2 x 16GB) DDR4-3200 Memory $394.50 @ Newegg
Storage Samsung - 960 EVO 500GB M.2-2280 Solid State Drive $209.99 @ SuperBiiz
Storage Western Digital - Caviar Black 4TB 3.5" 7200RPM Internal Hard Drive $181.89 @ Newegg Marketplace
Video Card EVGA - GeForce GTX 1080 Ti 11GB SC2 Video Card $749.99 @ B&H
Case Cooler Master - MasterCase H500P ATX Mid Tower Case $99.99 @ Amazon
Power Supply EVGA - SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply $75.98 @ Newegg Business
Monitor Dell - S2716DG 27.0" 2560x1440 144Hz Monitor $549.00 @ B&H
Keyboard Logitech - G610 Wired Gaming Keyboard $76.52 @ Amazon
Mouse Logitech - MX Master Bluetooth Wireless Laser Mouse $99.99 @ Newegg Marketplace
Prices include shipping, taxes, rebates, and discounts
Total (before mail-in rebates) $3788.71
Mail-in rebates -$40.00
Total $3748.71
Generated by PCPartPicker 2018-05-18 10:32 EDT-0400
IIRC X299 is limited to 44 PCIe lanes, Threadripper has 64. For your use case, PCIe lanes apart for the GPU and potentially fast network card (NAS, maybe?) are not really needed.
With Intel, it does not really matter. That said, 2666MHz should be in your budget.
Check the specs.
On that note, the H500P got the GN award for most terrible case. The airflow is shit-tier.
Go for NVMe and capacity, the little bandwidth limitation is not really interesting in every day use.
SeaSonic PSU calc says: 600W
BeQuiet PSU calc says: 520W
So any good 650W unit or better will do.
My attempt at this:
As PCPartpicker: Your Account - PCPartPicker
i9-7900X
Noctua NH-D15
ASRock X299 Taichi Xe (seems to have better cooling on the VRMs)
G.Skill Trident Z 4x8GB 3400MHz
Samsung 960 Pro 512GB
Samsung 850 Evo 1TB
2x WD Gold 4TB
MSi GTX 1080ti
Phanteks Enthoo Pro M (anything that has better airflow than the H500P :stuck_out_tongue: )
SeaSonic Focus Plus Gold 850W
2x Noctua NF-P14s (to help move more air through the case, 1080ti´s produce a lot of heat)
Total: £3385.08
