First PC Build HELP!
Im 14 Im currently saving for a PC that i want to build! Im planing to build a pc to run GTA V, Black Ops 3, Counter Strike and Stuff like that. Could you tell me if and what AAA Games i could run on this smoothly on medium to high settings or even low to medium settings. Thanks!
CPU: Intel i5 4590 Quad Core CPU 3.30 GHz
CPU Cooler: BE QUIET! BK010 Be Quiet Shadow Rock Slim CPU Cooler
Mother Board: Gigabyte Z97P-D3 Intel LGA1150 Z97 ATX Motherboard
Ram: HyperX FURY Series 8GB (2x 4GB) DDR3
SSD: Samsung 2.5-Inch 250 GB 850 EVO Solid State Drive
Graphics Card: EVGA Nvidia GeForce GTX 970
Power Supply: Corsair Builder Series CX 600 Watts
What budget what country, do you need a display and all that?
My Budget is £750 to £800 and im from the UK
And no ill already have a display from my xbox which i dont use anymore
With those specs, you could play any AAA game on high/ultra in 1080p.
But yeah, give more info :D
Well is it at least a 1080p IPS display?
Sick! What is the least i could spend to run most AAA Games just out of curiosity because i dont want to spend more than i have to. Thanks for the help
Probably this, In any case you should get a 390 over a 970, AMD cards tend to have more performance overall in the mid range, and Nvidia cards don't look to completely support DX12/Vulkan due to an issue they have with A-sync
Also a 1440p IPS display is around 250 Pounds, so add that in if you get a chance, or maybe get an SSD
The lesser build, the 380/960 are more 1080p cards, and the 390/970 are more for 1440p, although the 380 at least can handle 1440p pretty well
PCPartPicker part list: http://uk.pcpartpicker.com/p/29d9bv
Price breakdown by merchant: http://uk.pcpartpicker.com/p/29d9bv/by_merchant/
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor (£143.99 @ Amazon UK)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard (£68.29 @ More Computers)
Memory: Crucial 8GB (1 x 8GB) DDR3-1600 Memory (£27.99 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£38.97 @ Amazon UK)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card (£160.74 @ More Computers)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case (£29.64 @ CCL Computers)
Power Supply: XFX TS 750W 80+ Gold Certified ATX Power Supply (£64.94 @ CCL Computers)
Total: £534.56
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2016-01-11 20:32 GMT+0000
Thank you that seems like a much better option, would this build run AAA games on decent settings? Also thank you for the help!
I have an i3 and a GTX 960 and I can run Fallout 4 on ultra settings 40-60fps
Pretty much every game with a 960 can be run on high
except Arkham Knight, because those guys can't program proper
Thank you for the help just 1 more question out of curiosity becuase i want to spend as little as i can get away with how would this build perform with AAA games?
http://uk.pcpartpicker.com/p/XsF7bv
that's a video for the GTX 750 Ti
It's a pretty low-end card, but the CPU won't be a bottleneck.
Awesome! So basically the £340 build i linked would run battle filed 4 at medium to high well?
Should go for a 360, future support, freedom and all that, it's also 79 pounds, performs about the same as the 750ti
https://uk.pcpartpicker.com/part/xfx-video-card-r7360p2sf5
Also you should really buy an i3 over the pentium, some games like GTAV will not run well at all on a pure dual core, if not the 860K over the Pentium if you really wanna spend less
As little as possible would be like an APU build that'll run games well at 720p
PCPartPicker part list: http://uk.pcpartpicker.com/p/vdRvpg
Price breakdown by merchant: http://uk.pcpartpicker.com/p/vdRvpg/by_merchant/
CPU: AMD A8-7600 3.1GHz Quad-Core Processor (£64.39 @ Aria PC)
Motherboard: Gigabyte GA-F2A78M-D3H Micro ATX FM2+ Motherboard (£50.83 @ CCL Computers)
Memory: Kingston Savage 8GB (2 x 4GB) DDR3-2400 Memory (£40.50 @ Aria PC)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply (£31.99 @ CCL Computers)
Total: £226.68
Generated by PCPartPicker 2016-01-11 21:14 GMT+0000
Hows this?
http://uk.pcpartpicker.com/parts/partlist/
wrong link
sorry
http://uk.pcpartpicker.com/p/GKrDGX
The APU has a strong iGPU you wouldn't get a dedicated card with it, and the 2400mhz RAM wouldn't be needed either, here's the APU's iGPU benchmarks
Actually the price is so close to the 860K in the UK, Keep the A8 7600 the back up GPU may come in handy sometime
RAM here's a bit slower than what was in the build
A8
7650K | CS:GO/Dota 2/SC2 benchmarks Tested With 1866Mhz
RAM
A8
7650K | Various AAA titles Tested with 2133Mhz
RAM
http://www.anandtech.com/show/9217/the-amd-a8-7650k-apu-review-also-new-testing-methodology/7
So i could take the graphics card away?
