okay the price needs to be around $500-$700 and that's it BTW i have no idea how build a pc but ill take a look at tek syndicate's video on how i'm sure it's not that hard. im not going to play hard core games but i may just jump into BF4 from time to time i don't mind if i have to play on mid-high settings and get 30-60 fps but i dont want to be a slow pc i want to play a lot of games on
is the price including peripherals and os? or do you allready have those?
The $650 December 13 build by Tek is perfect for you.Of course that is excluding the price of the OS and peripherals.
http://pcpartpicker.com/p/2sInB
CPU: AMD FX-6300 3.5GHz 6-Core Processor ($116.98 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ OutletPC)
Motherboard: Asus M5A99X EVO R2.0 ATX AM3+ Motherboard ($114.98 @ SuperBiiz)
Memory: A-Data XPG Gaming Series 8GB (2 x 4GB) DDR3-1600 Memory ($62.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($59.98 @ OutletPC)
Video Card: MSI Radeon R9 270 2GB Video Card ($185.66 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case ($54.99 @ NCIX US)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply ($59.99 @ NCIX US)
Total: $684.58
https://www.youtube.com/watch?v=VMiUx5rbx6I
https://www.youtube.com/watch?v=O1p3BAR9pRs
i need everything but i dont need os i have windows 8.1 but i need monitor and keyboard no mouse i have a good one
that's too much i also need a monitor and keyboard if add those in it will go up to $900+
i need monitor and keyboard in the price too
http://pcpartpicker.com/p/2sIIg
CPU: AMD Athlon II X4 760K 3.8GHz Quad-Core Processor ($89.99 @ Newegg)
Motherboard: ASRock FM2A75M PRO4+ Micro ATX FM2+ Motherboard ($74.99 @ Microcenter)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case ($35.99 @ Amazon)
Monitor: Hannspree HE225DPB 21.5" Monitor ($109.90 @ Staples)
Keyboard: HP Stylish USB Keyboard and Mouse Wired Standard Keyboard w/Optical Mouse ($24.99 @ Staples)
Total: $696.48
Great build by cooperman.I think that'd fit the requirements stated.
Side note,aren't you able to find an old or spare keyboard lying around somewhere?That could help with your budget.You don't need an expensive keyboard right off the bat.
yeah i have a old dell keyboard how much would that help?
okay i may squeeze this build in and i want to know if it's good http://pcpartpicker.com/p/2sLmS
http://pcpartpicker.com/p/2sM54 this would be a good choise. I cut a bit here and there in the older builds, and managed to fit a nice IPS monitor and a nice CPU cooler for quieter operation and longer lifespan, due to lower temps. this would be around 688$ (no keyboard included since you have one :) )
I hope I helped you :)
Well.if that keyboard still works,you don't have to spend that 10-20 dollars and invest that on other parts of the build.
proman505 this build you made here is a good build realy. ☺
