First Pc build help!
I'm ready to build my first pc, and i was wondering if this would work and if there's any improvements tips ect?
http://pcpartpicker.com/p/y26Q
seems good to me, but you might wanna save just a little and get the 7870
Do you mean upgrade the graphics card to 7870?:s Cause that's more expensive xD
http://pcpartpicker.com/part/xfx-video-card-fx787acnfc
for 14 $ more, it is totaly worth it. In worst case scenario, get only 6 gb of ram or a smaller Hdd... anything works
Thanks:3 got it :D Would the build be good now?
http://pcpartpicker.com/p/y2L0
Looks pretty solid to me, and I agree on the 7870 upgrade. You get a pretty significant performance jump from it over the 7850, and it doesn't cost much more.
Thanks guys:)!
