First PC Build/ help and suggestions
Hi there,
I am planning on building a pc and wondering if these parts are ok. Im fairly new to this so im happy to take any advice.
I want to play games in 1080p, so it is a gaming pc, but also surf the web.
The parts i am considering are:
CPU: AMD FX-8320
GPU: GeForce GTX nVidia 660
RAM: Corsair Vengeance 2x4 gigabyte 1600mhz
Motherboard: Gigabyte GA -970A - UD3P
PSU: Coolermaster Elite 500 watt
Hard drive: Western Digital Caviar Blue 1TB
Do these parts work together? My budget is under £600
i'd change two things here
a) get a 760. It (debatable) outperforms the 670 for around the same/ less price.
b) get the Corsair CX500 "Builder" series. when it comes to PSU's Corsair has a more reputable name than cooler master.
hope this helps :P
Thanks Man!
It helps alot!
