So it is time for me to make a Gaming Computer, as I'm not convinced by the "next-gen" consoles , and because PC gaming is pretty awsome.
I wanted a good gaming pc that could last a long time and play all games at high to Ultra settings ; with the Bitfenix Prodigy design (I love that case). Since I'm in France (sorry if my english isn't perfect), I'm gonna make a list of what I've selected so far. My budget is around 750€ :
That should work. But check around on graphic card. although the 760 is a great card, now with the new AMD cards out I might be possible to pick up a AMD Radeon 7970 for about the same price. More bang for the buck.
the 760 will definently do fine. Just recommending you should look around at other outlets than amazon. Here in Sweden I can get a 7970 for about the same price as a 760.
If a 7970 isn't in your price range, you should see if you can afford a 7950, which is the best card price to performance wise atm, and will beat the 760.
I'm not too familiar with Sapphire cards, but that looks very good and after reading up on it a little I'd definitely recommend it. And if it is 199€(thats what I found anyways) then that would probably be the best card for your system, and I'd probably use the saved money to get the-doesn't matter
-Ignore this-Asus M5a97 R2.0(Sorry, amazon is the only site I know of available to you), as many Gigabyte Am3+ Mobo's have gotten bad reviews and are said to have a few problems with them(not too sure about that particular model though, will get back to you).-Ignore-
Edit:Just realised I did a stupid with the motherboard, I'll see if I can find a better mATX Mobo, but that Gigabyte board is looking better now...
So I just whatched and read some reviews : they just perform the same, It's just branding and little thing. I prefer Nvidia things like Geforce Experience , PhysX , GPU boost, etc etc. AMD seems more limited...
