hi guys. i need some help with part selection for my first build. im set on the fx 8350 as my cpu. it is a beast and the clock speeds are crazy high but im having trouble with my gpu and keeping the build under 900. i also need some advice on my motherboard. i like the sabertooth but it is expensive az. please can you guys give me some advice on the two components and maybe just a general build. the help would be greatly appreciated.
Something like this should do: http://pcpartpicker.com/p/2vj5N
i still need to get an os, wireless network card. what about after market cpu cooler?
this is my current build http://pcpartpicker.com/p/2vjlP
Here is an update of the above parts that I'd suggest http://pcpartpicker.com/p/2vm4i (edit changed mobo to the pro version rather than evo, its better and its price has fallen to similar)
Firstly I went to a 990x mobo instead of a 970, this will better handle the 8 core, expecally is you overclock. In fact Asus even claims this board can run the Mighty FX-9370 and 9590, so you can upgrade in future if that floats your boat. It also has duel 16x PCIe slots and both SLI and Xfire support, so if you want to run 2 graphics cards your sorted.
Speaking of duel graphics, you'll need a lot of power and the LEPA power supply didn't enthrall me, so I chose to go with a higher rated Seasonic PSU, its still bronze rated and is still modular but its not only a better brand but a higher current rating, so at nearly the same price its certainly my pick. With 620watts it should run duel graphics and a CPU fin as long as your not going stupid with overclocks on all three or wanting to run duel 780ti's or r9 290X's, then you'd need more than this to be sensible but would probably still get away with it since Seasonic supplies are so durable.
Final major change I made was the case, the Corsair 200r is worth a few more dollars but pack USB3.0, slightly better build quality, great ventilation (up to 5x140+3x120 fans) and cable management. Its also possibly the smallest case to still fit a full 8 slots, a reasonable number of drives and long graphics cards. Thus I'd recommend it over most other cases for a budget build, because in the end its only $20 difference, you live with it every day and if you get a decent case it should last you many years and builds. However cases are a very personal choice and you may like the other more, if so more power to you, the $20 you save will make this build update actually cheaper than the original, despite having mainly better parts. I'd recommend the Define r4 for larger budgets but that wasn't on the cards.
Other than that I just flipped the wifi and ram. Regarding the RAM Gskill had a faster (1886 vs 1600) set with the same capacity and CAS latency for less money, and having used Gskill extensively of late I highly recommend them, thus I went that way. Only real issue with that Gskill set is its the only non color matched component it this build for a blue and black theme (sheer luck, didn't look till now), but that shouldn't matter since the case lacks a window anyway. For the wifi I recommend is actually the one on my pc and hasn't ever caused any issues, it was just plug in and good to go, so with that in mind, good reviews and the same speed as the other D link i chose to go the Asus way and shave a few dollars back.
As for things you could change for a few dollars extra to improve this build, but won't fit in you current price point, firstly I'd go to a 2 or 3 terabyte HDD, you WILL fill it eventually and they are far cheaper per gigabyte of storage. Secondly I'd grab a small SSD to install your OS and often used apps to, the Samsung 840 EVO 120gb is my pick for SSD's. Of course more graphics is always good in games, but as you pay more you get less improvement for each extra dollar so take than into account before grabbing something super expensive, with this build as it is you can always add a second r9 270x in future should would need it though.
Well, 620w is cutting it real close. I switched it out to an XFX 650W PSU. XFX has a Seasonic OEM, so this'll give you a little bit more headroom. It's also cheaper.
http://pcpartpicker.com/p/2vpgH
First off 620watts was far from cutting it close, the system uses less than 450watts peak, only 72% of the 620w rating of a Seasonic supply that's rated for 24/7 operation at rated load (620w) at load 40 degrees C (remember on a 200r PSU intake is via a dust filter from outside the case so that's your rooms air temperature). Remember also that's a max loading that will only be consistently achieved by a synthetic benchmark on every component simultaneously (inc HDDs and optical drive), a situation that's never going to happen in the real world. Whats more I have seen Seasonic supplies perform at more than 10% over rated spec for extended durations without fault. On the other hand XFX probably rates a supply far closer to its actual failure point as they are a brand with a much lesser reputation. There are also other factors to the power board (which sea sonic OEMs in both cases) to consider, starting with non-seasonic parts like power filter caps and continuign to visable features like that the XFX is only semi modular, possible cable quality differences and how loud the fan is.Thus despite the very mildly higher rating of the XFX unit, I suspect that the actual power delivery potential is either basically the same or slightly in the Seasonic supplies favor, and would opt for the better brand name and additional features over the claimed 30w difference. However its OP's choice and really either supply will do fine, so if the money is very critical I'd consider the XFX, however in that case there are cheaper choices they'll get the job done without any of the nice to haves.
