Hi this is my very first PC build. I will be using a AMD FX-8350 as the CPU. Here are the specs, Please give me as much feedback as possible.
http://pcpartpicker.com/user/CreatureAndrew/saved/#savedbuild_270289
NOTE: I am getting the GPU, Hard drive, and the optical drive for free.
Please tell me if this will bottleneck and if there are any other problems.
aha well if youre getting those for free then whats your budget?
Not including the items I got for free. Around 600$
I'd probably do this then http://pcpartpicker.com/p/BVLn
case is completely personal preference
Slimm
6
I'd switch to a psu that is 80 plus, maybe bronze
enermax is godly http://www.newegg.com/Product/Product.aspx?Item=N82E16817194094&nm_mc=AFC-C8Junction&cm_sp=&AID=10446076&PID=3938566&SID=
