www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.1095784&cm_sp=DailyDeal-_-1095784-_-Combo
You guys think this is a good deal for my first pc build on a budget?
First of all, what is your actual budget?
Between 500 n 600
Not if you intend to play games on it, the GPU is very weak.
Weak parts all round If you intent to use it for gaming ect.. Just as a regular desktop PC for Internet browsing & watching videos with some mainstream 2d games Its good. I would add an SSD for a boot drive & ditch win 8 for win 7 (unless you want touch screen stuff) Have a look at Logans build guides for a system or give us your budget & tell us a bit about what you need it to do & we will help you get the wright parts that will suit?
http://pcpartpicker.com/p/t24q or go with a 7870
