First PC build (AUS)
I'm wanting to build my first PC as its my 17th birthday coming up.  My budget would be around $1100 (AUD) for  just the PC and i will need to buy a keyboard and monitor as well. I want to use PC Case gear as i have had good experience with them in the past. The monitor i will be buying locally but the keyboard i will want to buy at the same time as the rest of the parts.
I will mainly be using it for mainstream games at 1080p on the highest settings i can afford in the budget and some web browsing.  I want it to be small and portable yet able to be expandable which is why i went with the bitfenix prodigy.  I wouldn't mid having a play around with overclocking in the future for a bit of fun, nothing serious, so i thought i would leave off an aftermarket cooler until the time comes.   I will need an OS , windows 8 preferred as that's what I'm used to on my laptop.
For a keyboard i would like a solid nice keyboard nothing to fancy that doesn't have a numpad so i can fit it on the keyboard tray in my desk.  Mechanical would be best if there is as much difference as people say in them.
http://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=193713&action=wish_lists
This is the build i was thinking but any tips to save some money or improve it would be much appreciated.
Have a look at buying your components through umart. Reputable, lower price than pc case gear and cheaper shipping.
There are no Umart stores in my state :(
Quite a nice system there. PcCaseGear is a smart site to buy from.
http://www.pccasegear.com/index.php?main_page=product_info&cPath=193_1589&products_id=26092
That would be my suggestion as an alternate graphics card. The good thing about the 270 is if you overclock it, it can beat the 270x easily. I've used them, they are really really solid overclocks.  This isn't to bad a reference, same card different skin.
As for the ram, you could drop down to just 8 gigs, That's still plenty good for gaming. Corsair, Kingston and G skill all have nice choices for fast 8 gig kits, single or dual.
Really unless you want to try for another motherboard and/or CPU, you've got it about as cheap as you can for the kind of system you're looking for.
Pc case gear doesn't stock AM3+ Socket MiniITX boards Either, Which is a shame because if you wanted to you could for an 8350 for a good little gaming CPU, but that's a tad under what you seem to be looking for.
Anyway, good luck with your system mate!
Thanks so much for the help man i will look at the 270.
If you have any local PC place's, you should always check there for sales and other cheap little goodies. And if you plan to get parts down the line, make sure you get a good CPU cooler. Sometimes you can find a 770 or 760 cheap, and those are great cards too.
Again, good luck.
I just checked the price of the same components on umart and they aren't that different to pc casegear now (good that pc casegear have reduced their prices :)). 8gb is definitely enough ram, but for the same price grab this set http://www.pccasegear.com/index.php?main_page=product_info&cPath=186_912&products_id=16934 better timings for the same price. Other than that only other suggestion would be to grab an 80+ bronze certified power supply. Don't skimp on the power supply of all things. Consider this one http://www.pccasegear.com/index.php?main_page=product_info&cPath=15_535&products_id=22743 (I wish Antec would still sell a good one for cheaper like they did a few years ago, those were good). Oh yeah and as the guy above said, get a good CPU cooler.
You know that their is a new gigabyte FM2+ mini itx motherboard. Who know what will come of the new processors. I would get with an athalon 4x of some kind and spend a little more for the GPU.
One other thing, if you could persuade yourself to go with something other than the bitfenix and an itx build you might be able to save yourself enough money and grab an ssd. Just something to consider.
