Hey guys, I'm building my first gaming PC after moving from console. I have the parts picked out in the link below, but I'd like to hear any suggestions or tips you might have. Any help would be really appreciated.
http://uk.pcpartpicker.com/p/2hNtg
You forgot the link......
Sorry, should be up now
To start, i think the build that you have is great, but if you had a little extra then what i would suggest is switching your socket to am3+ and going with a six core from amd. Their performance is crazy and they perform very well in games
http://pcpartpicker.com/part/amd-cpu-fd6300wmhkbox
Ok, thanks for the input
Well balanced build as far as I can see without looking into what else you can buy in pound currency as your pricing is different than North American's. One suggestion is to remove the CD burner and put the money into an AM3+ fx 6300 because the bang for buck on that CPU is ridiculous. You need to change your motherboard aswell if you go with the 6300 but their are good options available in AM3+ aswell. This way you can just buy and DVD burner down the road and throw it instead of being stuck with an older generation CPU (not to say the 750K is bad it was a great buy a year ago)
Thanks, that's probably a bit out of my price range although I'll look into it
Try to fit another 4GB of RAM in there, and then I'll be pretty satisfied with the build. If you only have 4GB of RAM, it will max out quite often during gaming.
Alright, will do. Thanks very much
I thought going to an AM3+ motherbard would be bad, considering that it's about to be killed off
https://teksyndicate.com/forum/cpu/am3-officially-dead/147758
