hi i will be making a 800pound pc and was wondering if this build would be ok or if i should go cheaper/more expensive on certain parts, or if there is an alternative that would be better for the same price, you know where im going :) well these are the parts i have chosen EXCEPT for a case! i need help choosing a case for up to 52 pounds i guess 55 but no moar. i would be very grateful if you could find me a case that is epix for 55pounds max! :)
Intel Core i5-2500K 3.3GHz Quad-Core Processor - 166.97
Gigabyte GA-Z68XP-UD4 ATX LGA1155 Motherboard - 126.82
Kingston HyperX Grey 8GB (2 x 4GB) DDR3-1600 Memory - 28.00
A-Data XPG SX900 128GB 2.5" Solid State Disk - 85.99
EVGA GeForce GTX 660 Ti 2GB Video Card - 237.98
OCZ 700W ATX12V / EPS12V Power Supply - 77.41
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler - 26.65
Sony DDU1681S-0B DVD/CD Drive - 11.98
Thermaltake VM600M1W2Z ATX Mid Tower Case - 38.38
Total = 800.18
so if you think i could improve this and if you know a good case for 55pounds/- then i would be very grateful. i would also be very grateful for any feedback because of a certain part is bad or something lol. anyways thanks in advance for replys!
I HAVE FOUND A CASE LISTED IN PARTS! now all i would like to know is if this will all fit together and work happily every after! :D if anyone would be able to check this will work for me i would be so grateful!
