First Pc Build £800
This is my first pc build and i was wondering if this will be a good build. I hope to be able to play games like arma on mediem to high with good frame rate.
Cpu: Amd 8350 4.0mhz-139.19
Motherboard: Asus m5a99fx pro R2.0-99.02
Cpu fan: coolmaster hyper 212 evo-25.18
Ram: Kingston blu (2 x 4) 60.76
HDD: Weston digital cavar blue 1T-43.99
Gpu: Evga Geforce GTX 760 2GB-202.51
DvD Drive: samsung SH-224DDB/BEBE-11.96
Powersupply: Xfx 750W Semi modular-80.88
Case: Corair 200R-47.98
Case fans: Corsair AF120 performance edition (2 pack)-19.34
OS: Windows 8.1 (64 bit)-70.00
All looks really good to me. Should certainly manage ARMA on high settings.
I know you're probably considering a dual GPU setup, judging by your large power supply. But by dropping the power unit down to a 550W, and not purchasing the chassis fans, you should be able to stretch to a GTX 770.
Obviously, that would be preferable, and balanced. You can simply add additional case fans later.
^---- this
Yep, +1 to Berserker.
