First PC build $700USD
Any opinions on this build? http://pcpartpicker.com/user/IamDolfin/saved/2YPO
It will mostly be used for school work and gaming. Games such as Battlefield, COD, and some other ones that catch my eye. It doesn't need to run everything at max settings, but decent performance would be nice.
I need to try and keep it at or under 700 USD, and mainly buy from Amazon, Newegg, Microcenter since I am not the one buying it, so I would rather them buy it from as few places as possible.
I don't need a mouse/keyboard/monitor, nor do I need an operating system.
this will play bf4 at medium settings at a decent framerate
Amazon.com: Corsair Vengeance Blue 8 GB (2X4 GB) PC3-12800 1600mHz DDR3 240-Pin SDRAM Dual Channel Memory Kit CMZ8GX3M2A1600C9B: Electronics
Amazon.com: Sapphire Radeon R7 260X 2GB GDDR5 DL-DVI-I/SL-DVI-D/HDMI/DP OC Version PCI-Express Graphics Card 11222-00-20G: Computers & Accessories
Amazon.com: Kingston Digital 60GB SSDNow V300 SATA 3 2.5 (7mm height) with Adapter Solid State Drive SV300S37A/60G: Computers & Accessories
Amazon.com: Cooler Master Hyper 212 Plus - CPU Cooler with 4 Direct Contact Heat Pipes (RR-B10-212P-G1): Electronics
Amazon.com: Asus 24x DVD-RW Serial-ATA Internal OEM Optical Drive DRW-24B1ST (Black): Electronics
Amazon.com: WD Blue 1 TB Desktop Hard Drive: 3.5 Inch, 7200 RPM, SATA 6 Gb/s, 64 MB Cache - WD10EZEX: Computers & Accessories
Amazon.com: Corsair CX Series 750 Watt ATX/EPS Modular 80 PLUS Bronze ATX12V/EPS12V 744 Power Supply CX750M: Computers & Accessories
Amazon.com: Corsair Carbide Series 200R Compact ATX Case CC-9011023-WW: Computers & Accessories
Amazon.com: MSI Socket FM2/AMD A75/DDR3/SATA3&USB3.0/A&GbE/MicroATX Motherboard FM2-A75MA-E35: Computers & Accessories
Amazon.com: Advanced Micro Devices AD750KWOHJBOX 100W Quad Core Graphics Processor 3.4: Computers & Accessories
I'd go with the first build. It may not be as 'future proof' as the FMx socket, but I think its perfect for what you want to do.
