Hey guys, I've been wanting to build a pc for a while but i had to build one under a budget of $1000. Here is a list of some things that I've found. If you can think of anything better to put in here please let me know.
Corsair CS650M
AMD Radeon R9 Gamer series RAM
AMD A10-6800k (I'll probably wait until the next series of GPU's come out before I buy one)
Corsair Carbide series 200r
Gigabyte GA-F2A88X-Up4
WD 1tb hard drive
I'll also probably buy an H60 water cooling unit from corsair
I would not recommend the up4, bios sucks and it might die randomly on you like mine did me, I would instead recommend the Asrock F2A88X+ Extreme6+. I really would stay away from the the gigabyte board
I really like that build but I would use an air cooler in that price range. I had a cheap cooler master AIO water cooler and I hated it. The tubes wouldn't curve into a logical position and it seemed to big. Something like this would be my personal replacement: http://pcpartpicker.com/part/phanteks-cpu-cooler-phtc12dxbk
I'd get that PSU regardless.... $40 off is a killer deal...
it's an Asus Z87 chipset... Z87 is made for overclocking... it's virtually identical to the Z87-A minus the extra PCI slot and after that the prices start skyrocketing with unneeded bells and whistles... it's not like he's gonna run 1.7v on air cooling anyhow... I'm quite confident he can count on a baseline 4.3 GHz+ silicon lottery overclock on that board...
My only problem is that the board is pretty bottom of the bin, yes z87 is an overclocking chipset but I wouldn't over clock on anything less than a PRO, plus the cheap boards can have a lot of problems. I'm not saying its bad but I've had a history with cheap boards and I'm hardpressed to recommend one
Not trying to argue with you or anything... but most of the PLUS boards are just added features with identical VRM heatsinks (case in point with the plus, and c/a/etc models here... every line gets some DOAs.. Newegg's reviews are all 5 stars or 1 star DOA... I don't know what issues you've had with "low end boards" but the Z87 chipset in and of itself is a highend chipset... I've installed 2 of these boards on computers I've built and they run great, hence my recommendation... very few people use the added features that more expensive mobos supply... same board, more empty holes to plug shit into... :P
