So my budget is about $500-$600 (give or take) and I kinda wanna see if what I have on a list in Amazon right now is worth the money.
http://pcpartpicker.com/p/wwi6
I want feedback and it's ok to be blunt with me (even brutally blunt is fine)
Alternative: http://pcpartpicker.com/p/wtRJ
I would see if you can play around with it a it drop the 1TB for maybe a 500GB and a SSD and the noctua cooler for a hyper 212 evo it will save you some money and you can always buy noctua fans for it.
Thanks for the suggestions, man. I amended the list.
Looks like a nice simple build to me. Good quality parts and evenly matched. I don’t know where you are going to purchase these parts from but I would look around to see if they are available from others at better prices. I don’t know if they are but always worth the look. I will use Newegg.com as an example. Have fun with your build.
For the CPU, you might want to look into the FX-4300, the Zambezi CPUs aren't really all that good.
Don't get the scorpio blue it's a laptop hard drive. It'll work, just not really great. Just get a Seagate Barracuda 500Gb. Mushkin has a 2 x 4Gb 1600MHz kit for I think 36$.
Maybe roll down to a Phenom 965 processor, and a better PSU or motherboard or a bit to both.
My goof, that is a laptop hard drive. Go for a full HDD for a desktop.
this is my $700 gaming pc im going to be building soon http://pcpartpicker.com/ca/p/wlKT
Here's the build I was able to put together:
http://pcpartpicker.com/p/wKKE
965 for 1 more dollar....might wanna go for that....
