Hey guys
I had already a game pc planned but I calculated it and I have more money in 2 months so what do you think about this build for gaming? I am planning to play Bf3 on high and some Arma 2 :
http://pcpartpicker.com/user/xSvenHD/saved/1wsw
Hey guys
bigger HDD, maybe an ASUS DCU2 660ti?
Tom
save some more and perhaps get a low end quad haswell when they come out, plus something like a 7870.
everything else looks ok.
if you can, squeeze in a ssd into whatever build you go with. it is by far the best thing for any pc.
More storage comes later because this is the max money i can spend on build
I'd echo the further storage. You are costing yourself a good 50 quid by picking up a second HDD down the line - on amazon going from 500gb to a tb is a matter of eleven pounds, which even the lowest budget can't argue with.
Other than that your spec is solid and will handle BF3 at max without a hitch.
Good Point, i will buy a 1tb hdd instead of a 500gb thanks!
This is slightly better
http://pcpartpicker.com/p/UzPp
