Hey guys, after tons of help from people from this forums i have come to this build it total cost with everything is $1400.
http://www.pccasegear.com/sc/d7A
I'd like you guys to tell me what you guys think before i buy it. (i like the keyboard and it's just a little extra for myself )
I only want this build to be able to play WoW and LoL on best settings without lag and just to have a strong computer so i spend a bit more then i needed.
If you guys can tell me if this is pretty good for these games and theres nothing wrong with the build it will all work smoothly etc would help a lot! Thank you guys!
P.s limiting to one place so i don't have to pay more in postage.
well first where do you live, it helps since we have so many nations of people on this site. I'm in the USA and i have a feeling you aren't so my suggestions probably wont help but i pushed a couple of these into Google and found newegg has them significantly cheaper
thanks for the quick reply. i was already half done making this list though so i kept making it. I have no idea how shopping goes for people out of the US because I've never been able to travel, anyway i made you a list on a different site staying as close to your exact list as possible, unfortunately i couldnt find the fans or case but everything else is the exact same for almost 300 less (i converted usd to aus) anyway this is what i have, good luck though, ill monitor the thread for progress
