First Gaming PC Build. Does it look good?
I'm making my first gaming PC and would like to know if I should make any changes to it(cost effeciency or performance). Here is my setup(all were off of newegg.com).
Motherboard: Gigabyte GA-Z77X-D3H
CPU: Intel Core i5 3570k
GPU: EVGA GeForce GTX 660Ti 3Gb
Memory: Mushkin Enhanced Redline 8Gb DDR3 1600 Model-996982
SSD: Adata ASP900S3-128GM-C
Power Supply: Corsair HX750 ATX12v
Case: Zalman Z9 Plus ATX mid-tower
Thanks for reading please give me some feedback!
I built a computer for a friend in a z9 plus. Put your 8pin through the cut out before you install the mobo. Also idk how much better a 3gb performs over à 2gb at 1080 so you should look at some bench marks on that also only msi power edition 660tis can over volt if that is important to you.
Everything looks good, but perhaps consider having a lower wattage power supply, say 520-600 because you will not need it with a single 660ti. I would reccommend a seasonic 520 watt modular power supply (link below).
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151093
Also consider an aftermarket cpu cooler, especially if you are considering overclocking.
Thanks guys I will look into a different power supply and I may get a different graphics card if it costs less and still is fast. Thanks!
