First FM2+ build suggestion s
I'm building a pc for a friend. It's based on the fm2+ platform but i have little to no experience about them.  Can you guys recommend a solid board that preferably 80 bucks or under? Also needs usb 3.0.
Thanks
anything asus or msi is fine.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813132134&cm_re=fm2%2b-_-13-132-134-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16813132054&cm_re=fm2%2b-_-13-132-054-_-Product
