I will get right to it, this is my first time water cooling and I have some questions (which google proved rather unhelpful for).
My planned build is: (parts NOT listed are already owned or awaiting advice)
Corsair Obsidian 750d
Alphacool NexXxos UT60 360mm (in roof)
Alphacool NexXxos Monsta 280mm (in front)
fans for each (push+pull for monsta and push for UT60)
XSPC Raystorm CPU waterblock
Primochill PrimoFlex Hose (Clear or Red, still undecided)
Now for the questions.
A) where on earth can I find these that are sold in/ shipped to canada?
B) Will a GPU (NOT full-cover) water block work on my MSI 770 Gaming OC? (full cover would be nice but i am rather certain is does not exist)
C) Any recommendations regarding fans? Noctua is the obvious choice, but they are rather expensive. Is there anything with similar noise and performance characteristics that is more affordable for the student on a budget?
D) Coolant: What should I get? I realise this may me a stupid question to those who have build numerous water cooled rigs already, but for a disaster-fearing first-timer, this matters a great deal.
E) Tips/Tricks for hiding as much hose as possible from view
Thanks Teksyndicate community in advance
a) look for alternatives (xspc, koolance, hardware labs etc) if those rads aren't available locally.
b) check if ek has a block for it > ek cooling configg on their site. Worst case scenario there is universal blocks, but in all honesty with a nice windowed case that will show off your parts then uni blocks look like dogs bollocks. May be worth selling off the card for a reference model or at least one that has a block available for it.
c) noiseblocker's, scythe gt's, corsair sp's, bitfenix spectre pro's - anything with high sp, & can run at 7v or even 5v.
d) demin water + liquid utopia additive - cant go wrong & is cheap. imho the pre mixed coolant is way overpriced for what it is. If you want colour then select the colour tubing.
e) Plan the loop so you use as little tubing as possible. Get some inspiration from this lads builds >https://www.youtube.com/channel/UCqChlb8y4cQ0jAFaNFPQLqA< & review of the case so you can get some more ideas >https://www.youtube.com/watch?v=sCqSFB1wWl0<
Thanks!
Also, I have watched TTLs video on the 750d several times already (to ensure radiator compatibility). I complement you on your response sir!
Why is there no way to +rep on here?
Happy to help mate. Good luck with it all.
Here is a water cooling guide that I wrote should help you
https://teksyndicate.com/forum/cooling/water-cooling-noobs-all-one-guide/174585
WC stores
http://www.dazmode.com/
www.ncix.com
http://www.petrastechshop.com/
