First Ever PC Build
Hey guys I am new to building PC's and components but know alot about computing.
This build is going to be my first ever build after using a hand me down from my brother and I would like some help on getting the best performance out of it, and also like some help with component compatibility. So ill start.
Corsair HX Gold Series 850W Modular ATX - PSU
ASUS Crosshair V Formula AM3+,ATX - Motherboard
AMD Vishera FX-8350 4.0GHz AM3+ Black Ed - CPU
ASUS AMD Radeon HD 7970 DirectCU II - GPU
Corsair Hydro Series H100i - CPU Cooler
2TB Seagate Barracuda 7200rpm - HDD
120GB Kingston HyperX Series - SSD
Kingston HyperX Predator 8Gb (2x4Gb) DDR3 2133MHz - RAM
Generic DVD Drive
I would like some help on compatibility, for instance I've been reading up that the CPU only allows a max Memory of 1866 (does this matter ?) and the Motherboard says it takes 2133MHz(O.C) Memory. Does this mean I have to overlock my board in order for it to take my memory.
I really appreciate the help that you can give me :)
TTFN
AidanMarkSmith
I don't know about the memory support of the CPU but if the motherboard says 2133(O.C.) it means that it supports that frequency you just have to configure the memory yourself.
Nice build but have you thought of a case?
