Ill get right to it this time, I've had to re-write this post like 5 times now!
So im going to be playing a lot of games of course, and im stuck with under $700, as this is a "budget" build.
I will also like to render videos as i have a youtube channel and it would be nice to save some time there, I use sony vegas. rendering isn't that big of a priority but just throwing that on the table...
okay, here's my parts;
-antec new solution series micro atx mid tower case
-western digital Blue 1tb, pretty common for pc's im sure
-intel core i3-3220/corsair builder series 500 watt BRONZE CERTIFIED (bundle, save $15)
-Kingston hyper X series 1600 RAM 4gb (will upgrade to 8 down the road...)
-ECS H61H2-MV Socket 1155 motherboard
-HIS Iceq 3gb 7950 for $250! PRICES ARE REAAAALLY COMING DOWN!
So basically my main question is would it be worth to sort of "skimp" out on the motherboard and get a complete beast GPU? or should i stick with an ASUS 7870 directcu ii for $210, save $40 and spend that 40 on a "better" case, RAM, and motherboard by a little bit...
So in advance, thanks for helping out, and if you did reply back thank you!
okay, thanks for the reply, however i am having trouble understanding what you mean :P So you would recommend me getting a better motherboard and a 7870 rather than a cheaper motherboard and a 7950?
okay well im pretty set in stone on my choice to get the i3-3220, and i literally went for the cheapest mobo :/ lol. And i understand what you're saying now by the way
I prefer their cpus for gaming because games usually aren't too cpu intensive. No reason for the extra money. I prefer Nvidia for GPUs but since both Xbox one and PS4 are using AMD, the frostbite engine and crytex were announced to be optimized for AMD. It's the safer bet at the moment. I think other multiplat developers will have AMD and Nvidia running neck and neck or AMD slightly ahead because of this now.
