Alright hi, im looking to see if what i have here is worth the price of $785 and also if any of you have better build suggestions, im pretty much completely new at this and this would be my first PC build unless this is a good price. The build below is from cyberpowerpc.com where i picked everything and basically if its not that good of a deal i'll just build the pc myself. I'm looking for a pc to run Elder Scrolls Skyrim, Thief, Watch dogs, also smaller games like Left 4 Dead 1&2 stuff like that.
I use my tv as a monitor, and the os on this build is windows 8.1, a few things i was concerned about was the power supply, CPU, and Video Card.
CASE: X-Titan 100 MID-Tower Gaming Case w/ Side-Window Panel
CD: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive
CPU: AMD FX-8320 3.50 GHz Eight-Core AM3+ CPU 6MB L2 Cache & Turbo Core Technology
FAN: Asetek 510LC 120mm Liquid Cooling CPU Cooler - Enhance Cooling Performance (Single Standard 120MM Fan)
FLASHMEDIA: INTERNAL 12in1 Flash Media Reader/Writer
HDD:1TB Western Digital Caviar Blue SATA-III 6.0Gb/s 7200 RPM HDD
MEMORY:8GB (4GBx2) DDR3/1866MHz Dual Channel Memory (ADATA XPG V2)
MOTHERBOARD:* GIGABYTE 970A-DS3P AMD 970 ATX w/ Ultra Durable 4 Classic, On/Off Charge, GbLAN, 2 PCIe x16, 3 PCIe x1, 2 PCI
VIDEO CARD:XFX Double D AMD Radeon R9 280 3GB GDDR5 PCIe 3.0 x16 Video Card
NETWORK:Onboard Gigabit LAN Network
POWERSUPPLY:600 Watts - Standard 80 Plus Certified Power Supply - SLI/CrossFireX Ready
SOUND:HIGH DEFINITION ON-BOARD 7.1 AUDIO
Thanks for the help!
