Hmm my only thoughts would be wait for a month or 2 to just get a better graphics card. if you save the $150 from the 650 and add it to the $300 that you were thinking that you would get next month or two you can get a pretty badass GTX 670 and absoultly destroy any game you throw at it. If you do go the 670 route i would go with the MSI GTX 670 PE it allows you to give the GPU a little extra power so you can get a little higher preformance out of it.
