First desktop build please help
This is my first time building a gaming desktop and these prices are in AUS $. I am not going to be doing overclocking myself and this is for single 1920x1080 gaming. Could you please comment on the parts that I have chosen and give you input. Here is the link to the website as well;
http://www.umart.com.au/newindex2.phtml?bid=6
LiteON SATA DVD-RW 24X Black$20.00
Razer Arctosa Gaming Keyboard Silver Edition$47.00
SeaSonic M12II 620W 80+ PSU$131.00
CoolerMaster Silencio 550 case with USB3.0 SDCard Audio$89.50
Asrock Z77-EXTREME4 Z77/4 x DDR3/2 x PCI-E3.0/4 x SATA3/6 x USB3.0/HDM$136.00
Gigabyte GF GTX 680 OC EDITION PCI-E 3.0 2GB 256-bit DDR5, Base:1071 boost:1137/6008 MHz, 2x DV$560.00
SanDisk Extreme SSD 120G - SATA3/MLC/SF-2281/3Yrs$98.00
Intel Core i5 3570 LGA1155 CPU 3.4Ghz 6Mb Cache Ivy Bridge$210.00
AOC E2262VW 21.5 LED Ultra Slim Black VGA DVI$122.00
Western Digital 1TB SATA3 HDD 64M Caviar Blue WD10EZEX$73.00
Corsair 8GB (2x4GB) CMZ8GX3M2A1600C9B DDR3 1600MHz CL9 Unbuffered DIMM Memory for AMD, Intel Dual Ch$54.00
Microsoft Windows 8 Pro 64bit OEM$150.00
Total $1690.50
you're going to get shafted with the razer, otherwise everything is shiny
[img]http://i.imgur.com/dhySH.gif[/img]
ok so could you please recomend a better keyboard for nearly the same price.
what do you need a gaming keyboard for? the looks? because in most cases it makes no difference unless you type a lot, if your writing or programming. In most games it won't make much difference, and you could save some money this way.
Unless you know how it feels beforehand, or have the guarantee that it's reliable and feels good to the touch (like in the case of mechanical keyboards), you can't categorize keyboards. I've played games seriously on cheap membrane keyboards, as the mouse was more important (I have a razer diamondback since 2004, i've heard bad things about their keyboards, and newer mice that use the so-called cloud drivers, useless limitation in my opinion).
You could go with a quality Microsoft keyboard that fits your system's colour, maybe even a Sidewinder (their gaming line of peripherials), if it fits your liking.
I really want to recommend you a mechanical keyboard like the QPAD MK85, but it's out of your price range. You just can't go wrong with a mechanical keyboard.
For the price range, I've heard good things about the Roccat Arvo (mainly from gaming buddies)
Thanks for the help ill swap out the razor for another brand like what you recomended.
Exactly against my view, but to each his own. You could find a non-gaming keyboard suitable for everything, like cherry, or ibm with different key caps and switches.
The Logitech K120 is considered to be the ultimate cheapo around these parts. It will probably work fine. You might even find a working, scrapped keyboard in your (or someones) garage. (and if you're really lucky, it might just be an old mechanical one)
all of the PC looks great, as for the whole keyboard discussion no one can tell you what keyboard to get as each feels different and people like different things. iv got the microsoft sidewinder X4 decent price nice feel. backlit with option to turn it off, media buttons. not too flashy but its got what you need :)
Thanks what would be your opinions on this one?
cheap, backlit keys and multimedia keys across the to which I really like.
http://www.umart.com.au/pro/products_listnew.phtml?id=10&id2=40&bid=6&sid=103885
