First desktop build Help/Discussion
Hello Tek Syndicate! New to the forums but been watching logan for a while.
I am posting because I am planning to build my first gaming/study pc within 2 weeks and would like advice/help. I would like to keep the budget at about $1000 - $1100 If you guys have any recent lists of parts for a pc you recently build on a similar budget feel free to just post that.
Goal: Decent multitask PC with room for future upgrades. Games would like to play: Starcraft2, Civ5, Elder Scrolls, miscellaneous, no BF/Cod. I would like to be able run a light game, have skype open, with itunes, and maybe a browser with 6ish tabs of text without lag. Occasionally I am going to want to have 1 VMWare Virtualization running or RemoteDesktop/SSH connections because of my courses. Basically want to be able to run 3-4 of any these programs smoothly.
These are some parts I am considering. http://pcpartpicker.com/user/dagungo/saved/2Tbx  .Not including external peripherals, OS, or a monitor(23" Acer HD) in the budget.
a Few questions:
1). Is there a good time within the next 2 weeks of sales to look for certain parts?
2). How much RAM do you think is right for my goal? and at what clock speed?
3). From my link are there other parts I should seriously consider? e.g. performance, price.
Any tips regarding the build and upcoming sales are more than welcome. Thank you for reading.
Standard advice: Get a FX-8320, get a much cheaper motherboard, don't get a 80+ gold, bronze is enough and much cheaper. Leave out the WiFi controller, you really don't want to use wireless for gaming. The RAM's good. Use the money you save to get a R9-280X :)
Is there any performance loss in using PCI-e 3.0 Graphics cards on a 2.0 Pci slot?  Most AM3+ sockets only come with 2.0.  Thank you for the rest of the tips tho!
I was also looking at amazon and their planning to make some SSDs 50% off.
You'll only see a minor performance hit if your doing a build with multiple graphics cards(ie crossfirex/sli) when using pci 2.0
"Is there any performance loss in using PCI-e 3.0 Graphics cards on a 2.0 Pci slot?"
There is no noticeable performance loss.
I have an Intel i5 3570K and do pretty much everything you've stated.  I can have TF2/Civ5, Chrome w/ 10 tabs open, Skype(occasionally, doesn't really affect anything), Steam, and Itunes open and have the computer work perfectly fine.
For your application, I would stick with the i5, as you don't have the requirement for any rendering or stuff like that.  Having each core be stronger will help as the games you're going to be playing won't optimize for 8 cores.
But even without the optimisation for 8 cores it's just as good in most games, and I guess it will be better in most future games.
The AMD FX-8350 is a great processor.  I agree that it's not bad at all for gaming.
However, the OP is not going to be video editing, or rendering anything.  He's looking at gaming and web browsing.  I usually recommend the FX-8350 for productivity/gaming builds, but he's not doing any productivity.
The FX-8350, even with a decent motherboard, can be had for quite cheaper, though.  The FX-8350 has a better price-performance ratio than Intel's i5.  I prefer Intel for their better single core performance, as many of the programs I use don't optimize for multiple cores very well.
