Right, so I just joined the forums, and I came to ask one simple question... What do you think of my first custom build? I'll just list the specs here, also, feel free to let me know if there's anything that I should change.
Processor: Inter i5 3570k
Graphics Card: GTX 680 DirectCU II Top
Motherboard: ASUS Maximus V Formula
Cooling Unit: Corsair H100 Factory Refurbished Water Cooler
RAM: Corsair Vengeance 8 GB (2 x 4GB)
Hard Drive: Western Digital Caviar Black 1TB
Case: NZXT Phantom 820 (White)
Power Supply: Corsair HX850W 80 PLUS Gold
Optical Drive: Lite-On iHAS 124-04
So, I am building a gaming PC and my budget is around $1500, but not limited. This will cost me around $1800, which is fine. If you are wondering about my Motherboard or Powersupply, and think that they are too much, it is because I am planning on upgrading to a second 680 of the same model, and I would like to have room to do so. To my knowledge, that motherboard and powersupply will be enough to handle this particular upgrade in the future, but if that is not the case, please let me know so. Speaking of cases, I chose this one because I believe that has a good airflow, and will keep everything pretty cool, and I think it should be able to hold everything easily. From where I am buying the case, it should cost $190, and if you think I can do better with that money, agian, feel free to let me know. Anyways, with this build, will I be able to run games like Battlefield 3, Far Cry 3, Borderlands 2, etc. etc. etc. on high settings, at a decent framerate? (before the upgrade to a second GPU, of corse)
Thanks in advance.
