First Computer Build (Around $1400)
Hello everyone,
My current computer is 4-5 years old and I am not able to upgrade it since it is a pre-built computer. Because of this I decided It was time to build a new computer.
This is what I am thinking about going with right now: http://pcpartpicker.com/ca/p/uuSM (Side Note: It shows that the motherboard that I have selected wont fit into the case but the motherboard is actually ATX sized motherboard)
I know I am going overkill on a few items (such as my motherboard and PSU), but I got them as recomendations and they do fit withing my budget (Around $1400). If you do happen to suggest a different motherboard I would enjoy if it had a built in WiFi card since that is the only way that I connect to the internet. Other than that, go crazy.
Thanks in advance and I can't wait to hear what you guys have to say!
http://pcpartpicker.com/ca/p/uB3G
A little cheaper, doesnt have a "built in" wireless card, but I added one you can add. This PSU is a more reliable brand then OCZ and is partially modular. Picked the same case, because thats a prefrence thing. Slightly cheaper SSD with similar performance, cheaper GPU with the same power as the GTX670 (just keep the Nvidia card if you use Adobe products but for gaming the AMD card is currently better). Cheaper Mobo with similar feature set, but fits in the case (EATX board doesnt fit in that case). Added a really nice CPU cooler.
I would use this: http://www.newegg.com/Product/Product.aspx?Item=N82E16833127481 Instead of wireless. I used both, powerline has less fluctuation.
Actually the motherboard is bigger than ATX but smaler than EATX.  It's about an inch wider than standard ATX motherboards.
Regardless, it should fit nicely if that's the motherboard you must have.  If not, a Gigabye GA-Z77X-UP5 TH is about the same price range as the G1 Sniper 3 but you lose out on the full sized PCI-E slots and dual LAN.
Change the SSD to an OCZ Vector or Samsung 840 Pro since you're already spending that much money.
For that price, you may as well pick up a NZXT Hale 90 750w 80+ Gold PSU.  No point getting a bronze Corsair.  Hale 90 is a rebranded superflower golden green so you're getting a good PSU.
I'd probably add a CPU cooler.  Memory Express has the Ncotua NH-D14 on sale for like $50 which is a pretty good price.  Otherwise you can just go for the budget friendly Coolermaster Hyper 212 Evo.  or Corsair H100i if you want watercooling.
