guys please help me, what do you think about this build : http://pcpartpicker.com/p/mmKGYJ
i got a 1T harddrive so i dont need to buy.
Thanks for helping
Looks good to me the only thing that I would upgrade is the ssd just to a higher storage capacity because in the future you may decide to store other programs on the ssd alongside windows for faster performance.
You will find 64gb ssd requiring to much management in windows. It is doable?
alright thanks, i will make sure to get a 250gb SSD
nice. my only suggestion, other than the SSD upgrade, would be to ditch the thermal compound. I mean, unless you are going for arctic mx-4, tuniq, IC Diamond, etc., the thermal past included with the hyper 212 will be just fine.
ty i will do that
