is that a good price/quality gaming computer for under 1500$ cad http://ca.pcpartpicker.com/p/fvCKbv
i would go with a cheaper case at that price point but solid build
Wouldn't buy smaller then 240gig SSD also prob don't need an AIO.
$150 is really the least i would ever spend on a case anything under that usually sub par quality.
my r4 was $80 new and shipped to my house
i only need ssd for the os and the case is a preference but is this a good price to performance gaming computer
ok but i will keep the case is one of my favorite case but do i really need aio for oc to 4.5 ghz if i get a good proccesor
SSDNow V300 is a really crappy SSD - Kingston switched the nand flash in them.
Other than that, the build looks pretty good.
i change the ssd to a Sandisk Ultra II will it be better ? http://ca.pcpartpicker.com/p/djnKbv and for overclocking cpu and gpu will my psu be sufficient sorry for my writting im french
