First build
I'm gonna be doing my first build in a couple months and I would like to see any suggestions on my current build. I'm not a set budget yet but I also want to keep it as performance as I can without breaking the bank.
http://pcpartpicker.com/p/BjgwHx
There's the link to the build. Any help would be much appreciated.
If you aren't building and buying now or in a couple days, I recommend asking again as prices always fluctuate and parts may be released in a couple months.
If you do have any questions, though, we'll happily answer them for you.
Currently the build you have now is a bit weak on the GPU, but not bad.
http://pcpartpicker.com/p/frBbGX
I added an SSD, and upgraded the graphics card, and changed some parts. It is more expensive, but I think the performance and experience will be worth it.
**As mentioned before, prices and availability will change in a couple months, but this is about what I would look at. I might recommend getting a devils canyon i3 with a better graphics card if the prices are right as well.
