First Build
I think I have finally decided what I want to put into my first gaming pc build. Please let me know if there is anything that I should change that will make it better or somewhere where I can drop some of the price.
AMD FX-8350
Asus M5A99FX PRO R2.O
A-Data XPG V1.O 8gb 1600
WD 1TB caviar blue
GTX 660
Corsair CX 500w
NZXT phantom 410
Windows 8.1
Cooler Master Hyper 212 Evo
Dat double post.
Your build is a bit weak in the GPU side.  Not sure what your budget is, but this should be close:
http://pcpartpicker.com/p/3sDoK
Is that motherboard good for overclocking?
Yes.
8+2 digi+ power phase design.  If you want to get into anything higher than mild overclocking, look into a better CPU cooler such as the Noctua NH-D14
