First build
I'm looking for help on my first PC build.
My budget is 550 and i would need an OS.
Any suggestions?
Check out the tek's budget build videos.
This build will be a good starting point, with room to upgrade to a dedicated GPU later on if you want to play newer titles at higher resolutions/framerates.
http://pcpartpicker.com/p/2pYuy
