Define cheap with a possible range of figures.
Jeseri
3
SSJ11
4
Price range is needed. Can't put together a build for you if you don't define "cheap".
Cheap could be $350 or $500 or $450....it needs to be specific. what is the absolute MAX that you're willing to pay for this rig? (excluding tax)
I'm going to be honest, for that price point you're going to get something less than astounding. This is the best that I could come up with
http://pcpartpicker.com/p/1IFpx
Just be aware that if you decide to get a proper cpu cooler and overclock, you can't push it very far on this board
http://pcpartpicker.com/user/paul_sauce/saved/2twY
this list comes out to $420, but it is worth spending the extra 20 bucks for what you want to do with this pc.
