I was wondering if Iwas making any terriable mistakes with my build. Thanks for your time!
http://pcpartpicker.com/p/O0kz
P.S. Here's a song for your enjoyment:https://www.youtube.com/watch?v=NkJrBBD3xpE
First of all at micro center you can get a deal for mobo + cpu bundles so I'd do that. For that same price you could probably get a fx 6300 and a 970 mobo. The hdd is only 500gb and for $60-70 you can get a 1tb which is probably worth it. As for the gpu, I'm not sure. I personally would try to find a cheap 7850, or a better deal on the 7770.
http://us.ncix.com/products/?sku=68528&vpn=FX777AZNF4&manufacture=XFX&promoid=1334
http://us.ncix.com/products/?sku=77602&vpn=FX-785A-CNL4&manufacture=XFX&promoid=1334
Both of these also come with free games, farcy 3, tomb raider and bioshock (respectively for the 7770 then the 7850). I'd probably also go with a cheaper like $40 case, and I don't think you'll really need 650w unless you plan to sli in the future with the same psu
You need a aftermarket cooler like a hyper 212
not bad but you can have this for a extra $20
http://pcpartpicker.com/p/O0Ml
CPU: AMD Phenom II X4 965 Black 3.4GHz Quad-Core Processor ($92.99 @ NCIX US)
Motherboard: MSI 970A-G46 ATX AM3+ Motherboard ($74.99 @ NCIX US)
Memory: Kingston 8GB (2 x 4GB) DDR3-1600 Memory ($61.91 @ NCIX US)
Storage: Western Digital Caviar Blue 500GB 3.5" 7200RPM Internal Hard Drive ($59.26 @ Amazon)
Video Card: PowerColor Radeon HD 7850 1GB Video Card ($169.99 @ Microcenter)
Case: Gigabyte GZ-P5HB5C (Black) ATX Mid Tower Case ($37.98 @ SuperBiiz)
Power Supply: Silverstone Strider Essential 600W 80 PLUS Certified ATX12V / EPS12V Power Supply($66.30 @ Newegg)
Total: $563.42
That looks pretty good. Plus you get crysis 3 for free from micro center ^
http://pcpartpicker.com/p/O2Co
